GE Refrigerator - Ice Maker Not Working
Ice maker on GE Profile Refrigerator (SIDE-BY-SIDE) not working. Water is in line. Ice Maker Arm goes up and down, but no ice. Any suggestions. Items to check or do I need to buy a new ice maker? Please help, thank you for your time. Have a good day!!!
First I would verify your freezer temperature near the ice maker is below 10 degrees and not below zero.
If OK, I would locate the water solenoid in the back and swap, if possible, the electrical wiring plugs, then press the water dispenser for 7-9 seconds. Water should fill up the tray. If not, you have a freezer fill tube that is frozen, or a bad solenoid, just remove the smaller tubing at the water solenoid and check.
If ok, you probably have a bad ice maker.
