Every time we close the door on the refrigerator, there is a piece of the shelf on the door that keeps hitting the light switch and the door will not close unless you lift the door upwards with the handle, over the switch and then push it closed. Kind of like the side of the door that opens is hanging down too low. Any way to raise it up?
You can add shim washers under the door.
