Brand: GE
Model Number:TFX30PPDBWW
How to assemble the pull out shelf to the metal piece that holds it to the back of the freezer
Main Symptom:
Brand: GE
Main Symptom:
The shelf will hook into the rails on the back of the freezer. The pull out shelf itself has 2 rails that attach to the shelf and then the wire part will slide into that.
Hi Ed; I understand the metal piece hooking into the back of the freezer and I see the rails on the pull out shelf that I assume slids into the metal piece, but I can’t figure out how. Any thoughts?
