Hi I just recently moved into a new house that 1 burner was not working on the electric range. I turned the burner on and it threw sparks out, now the range is not working properly the clock will only work if the oven or burner is on but nothing heats up burners or oven. I completely unhooked the 2 wires going from the bad burner. but don’t see any shorts anywhere what can I do? Do I need to do? Any help is appreciated!!
Update:
I got the range working turned out the breaker needed reset because it was getting some power but not all. But now the burner on light is staying on any ideas??
