I saw Range Oven Fault codes thread but I did not see any mention of F7 Error.
I have GE Electric Range JSP42W5WW which is showing F7 d6 error.
It beeps continuosly until I press Clear then it will stop & start beeping after 5 mins. If I press START it stops beeping but it shows F7 d6 error .
My oven does not work.
I will appreciate your help.
Is it Key pad issue or ERC issue?
Most likely the problem is a bad key panel, but there is a small chance for the control board to be bad as well. GE does not give us any reliable way to test it. I would replace the key panel first. If you need the correct part number, post the color of it.
