GE Range Control panel replacement part not the same
Brand: GE
Model Number: JGB660EEJ2ES.
Main Symptom: Control panel died
What happens & when: Oven doesn’t work
Replacement part:
WB27X44729 (AP7208367)
Quantity: 1
Cost: $91.68
We had a power outage. When the power was restored, the control panel error code was F8. Tried the advised tricks to get it going…unplugging, waiting, etc. But it didn’t work. So I ordered what is supposed to be the correct replacement part for my GE stove from appliance pro. Unfortunately, the replacement panel has different wiring. ,I wrote to them, and was told it was the correct part, but that I need to get it rewired. Which means hiring an electrician, as this skill is not in my toolbox.
My question: Is there really not an exact replacement for this panel? This should have been a very easy repair. Remove wires from the old, plug them into the new part.
Any help is appreciated!
GE model number:JGB660EEJ2ES. Serial # DH200354P.
Error Code (if any): F8
Parts or tests already tried: WB27X44729
Check out the photo of the new panel that shows the new part with separate plugs for TB 105, which is orange, and TB 106, which is white.
Meanwhile, the old panel has a single port for two wires, labeled J 100, with one wire being pink instead of orange, and the other white.
Looking at the last photo, it looks like the old board has a J100 and a J400 which the new board has as well. The old board does not have the TB105 and TB106 but the new one does. With only 3 connections points on the old board, you would simple use the same connection points on the new board without having to use the TB105 and TB106. The board should work without those connections. The manufacturer placed those on there for other models that would need them but not all models require them..
Thank you so much! I will try it!
I did it! She’s working again! Many thanks for the great advice! As I think I mentioned, electronics are generally not in my wheelhouse. I learned something!
Kind regards,
Maggie
