Brand:GE
Model Number:RGBS400M2WW
Main Symptom:all burner igniters don’t work
What happens & when:turn knob
Gas but no ignition
Brand:GE
Gas but no ignition
This would likely be a spark module failure if the burner heads are thoroughly clean. An easy way to verify would be unplugging the power cord, turning the gas supply off, and testing the burner switch harness for continuity when in the on position. If the harness has continuity, the spark module has failed. WB13X24323 Ignition Module Spark Module | Genuine Ge OEM In Stock
