The soap dispenser inside dishwasher does not seem to open when running. I have tried all the different cycles, but to no avail. I have also tried to reset the machine, but i’m still having the same problem. Any info would be greatly appreciated.
A Model Number may help others help you.
Remove the door’s inner panel and take a look.
Many of these units open the soap dispenser mechanically.
Could be just a spring came off or you have a broken part.
