Need some help…
I bought a used (but in what seemed to be good condition) GE Profile.
The family had just had a technician on it some time soon before I bought it from them. They did tell me that it had a difficult time keeping temperature sometimes - in both the freezer and the refrigerator compartments.
So… After a few weeks, sure enough, the freezer (set at 0) and the refrig (set at 37) began to climb. The freezer hovered between 15 and 20 and sometimes a bit higher - and the fridge between 43-47.
I first started to use a hair dryer to get the frost off the freezer coils… it would work ok for a day or so and then back to the old behavior.
Then I watched some videos on youtube and tried changing out the freezer temperature sensor (only one) and then changed the defrost thermostat (that clips to the top tube to sense the temp up there).
It seemed to work great - making ice well, staying cold and I thought I had gotten it figured out… Well… I didn’t.
I am back to the elevated temps and the ice in the ice maker melting a bit, then sticking to itself when it does get cold enough so the ice needs broken up before coming out of the dispenser. Sometimes when I set my ice maker on quick ice, it seems to get really cold again for a day or so, makes a lot of great ice, and gets below zero in the freezer. Then, when it stops making ice, it goes back to elevated temps and doesn’t really keep the ice frozen well… it drips water to the lower shelves in the freezer - then all that refreezes…
Is it my motherboard?
Might it be my defrost fan (at top of freezer compartment). I don’t hear that come on like I think it should… because when it is acting up - it sounds too quiet in there (I think).
I’m thinking it’s my motherboard - but that is the most expensive of all the things it could be… so I wanted to check with this DB - before I spent the BIG bucks…
Can anyone help?
Thank you!
