Roughly 2 hours into a 4 hour self cleaning cylce an error code of F2 came up, was beeping and the locked door kept flashing. After a half hour of the beeping we finally got that to stop and the error code went away but the locked door is still flashing and the oven will not turn on. We have turned off the power at the fuse box to the oven for 15 min+ but no change. Any ideas/suggestions on what to do to reset it? I thought I had read somewhere in line that the code showed that the oven reached a dangerous temp so probably shut down for this reason. Repair guy can’t come for 3 days and my wife is trying to bake for X-mas so I need some help here. Thank you.
I corrected my note to show the error code was F2 vs FE12, and was while cleaning.
What is the complete model number of the oven?
I have looked all over and can not find anything that shows me a model number? Any suggestions on where I would/should look?
Gene here is the model number J TP18WOW1WW. Hopefully that helps.
I appreciate your willingness to try and help.
“F2” error code means the control senses runaway temperature.
Open the control panel, locate the two wires from the oven sensor and measure the sensor resistance. It suppose to be about 1100 Ohms at the room temperature.
If the reading is correct, replace the control board.
If the reading is wrong, remove the oven from the cabinet and measure the sensor resistance at the sensor plug behind the rear cover.
If the reading is still wrong, replace the sensor.
Here are the breakdown diagrams and Replacement parts for General Electric JTP18WW1WW Electric range | AppliancePartsPros.com
I greatly appreciate your help.
