When I bought my house 5 years ago it came with a GE Profile top load washer / dryer set. They have been working well since, but now I think I am about to have a problem. After running a load (washer still works fine), the washer has a heavy odor of gear lube. I pulled the front panel off last night and there is oil slung all around the innards of the washer below the tub. So I have a few questions.
Do these little transmissions ever develop repairable leaks? Or should I just order a new transmission and swap it out? Are there any other parts I should order with it, such as seals, bearings or any other hardware? Are there any special tools required that would prevent this from being a DIY project?
Here’s the transmission: GE WH38X10002 Transmission and Brake Assembly - AppliancePartsPros.com
thanks for any help
