GE Profile Top Load Washer will not agitate
Brand:GE
Model Number:PTW700BST0WS
Main Symptom:no agitation
What happens & when:clothes not getting clean
Parts or tests already tried: Lid lock mechanism has been replaced. Did not fix issue. Machine passes the spin/lid lock test. Machine will spin and drain but not agitate.
Hey Mike, being that it will spin and not agitate, that points to the shift actuator being my number one suspect. The actuator does exactly what it says it does: it shifts the gearcase from spin to agitate. WH03X31937 Mode Shifter | Genuine Ge OEM In Stock
Understood.
One last question before I get that part…
I removed the wash plate to see if the splines were stripped. They appear to be in good shape (although the rubber washer underneath is totally disintegrated)
I noticed when I put the wash plate back on the shaft 2/3 of the way and turn it, the splines catch the shaft and I can rotate the entire drum.
But when I drop the wash plate ALL the way onto the shaft the splines no longer catch and the wash plate spins freely with no drum movement.
Could this be a wash plate issue? How can the splines catch when I lift the wash plate about an inch but not catch when it is lowered back down into its proper position?
