Brand: GE Profile Stove
Model Number:PS960SL1S
Main Symptom: stove tops nor oven is working
What happens & when: Board 270 caught on fire. I replaced the board. The lower oven light now flashes but the oven nor the burners work. I hear a clicking sound coming from board 415 anf there is a red light flashing on board 415
Error Code (if any): No
Parts or tests already tried: Replace burnt board 270
Photos / video link: Im not sure how to link.
The GE range/oven flashing red light on a GE range control board often indicates a fault, and the first troubleshooting step should be to reset the board by unplugging it for a min. of five minutes. Check for damage to the board and the wiring. Check for a tripped hi-limit, and then if it continues flashing the board will likely need to be replaced.
https://www.appliancepartspros.com/repair-help/
Thank you, Im not sure where to find and reset the hi-limit?
The reset is done by turning the power off for about 5 minutes. The hi-limit is on the back of the oven (part ref# 158)
Thanks, I have unplugged the oven, and still have a flashing. Though there is no apparent issues with board 415 other than the red light flashing I assume I would give it a try and purchase another board? Should I also replace hi-limit 158?
You would only replace the hi-limit if it reads open.
How do I check if the hi-limit reads open?
Using a multimeter to check for continuity.
[Multimeter]
(https://www.youtube.com/watch?v=UufisfyQlDg)
