Ge profile gas range broiler delay
Brand: GE
Model Number: unsure (profile gas range)
Main Symptom: broiler delay
What happens & when: Often times my broiler will not ignite. I see the pilot light on inside the oven but the flame does not come. I notice that often times I need to turn on one of the top burners and within seconds, the broiler turns on.
Hi bpmessenger, I’ll need your model number to confirm, but based on what you’re describing, it sounds like you may need a new igniter.
Thanks - the model number is pgb911zejss
Any updates on this?
Also, to be clear the broiler eventually does ignite but usually after a long while or turning on one of the range’s top burners. Almost like the gas flow is connected?
Still think it’s the broiler igniter?
Hi. This is the most common solution. Because the igniter is wearing out, it will eventually stop working altogether. Replacing the broil igniter takes about 30 minutes and restores the proper current draw to open the gas valve instantly.
Ah, so the igniter current draw is tied to the gas valve opening?
I noticed that this is a fairly simple replacement. Since the range is fairly fixed in place it’s near impossible to get to the back of the oven. Is it possible to get the clips out via the back port inside the oven? Or will wires need to be spliced?
I’ve seen situations where you cannot get the clip out via the inside and splicing the wire would remove the high-temperature coating.
You should be able to access it from the front. In my experience, I’ve usually been able to make this repair by going through the front of the stove. Depending on your specific model and setup, some wire splicing may also be required.
Thanks, if splicing is required, how would you advise shielding the wires after? Clearly regular shrink wrap will not be heat resistent enough?
Ceramic nuts, etc?
Thank you!
The wires shouldn’t be anywhere near the heat. Just make sure you leave enough slack in the wires so you can safely tuck them behind the shield wall in the oven cavity. Ceramic wire nuts will also work well for this application.
Got it thank you for your advice.
You’re welcome! I hope everything works out for you and you’re able to get it fixed.
Installed today, lit up in 30 seconds 3x. So hopefully you solved the problem.
Thank you
Awesome, you’re welcome! Glad I could help.
