Ok, No heat but motor still runs and timer works. Heating element is good so are the thermostats and safety switches. Also checked for continuity on timer and heat select switch (all good). I have power at wall socket (220) and I even checked the power cord for continuity which is also ok. I hear the centrifugal motor switch close when I turn the start switch. I even checked for continuity of the wires to both sides of the motor switch and both sides of the heating element. I have good airflow in and out of the dryer. Can anyone tell me what I missed?
Hi.
Make sure that you checked all four thermostats.See if you can trace the leg without the 120V.
The timer contacts B-A should be closed.
Not much left. Good luck.
Simon.
