Ge Profile Dishwasher
ON MY DISHWASHER the scroll arrows( up and down) selections button does not move off of normal cycle…HELP
Replacement parts for General Electric PDW9880J00SS Dishwasher | AppliancePartsPros.com
Here is a manual although it does not actually say it covers a 9800 series it may be close. At least, it is the best I can do.
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Check to see if the delay hours key works if not then odds are there is a problem with track 11 as it is common to all 3 keys. Could be the keypad or the control board. The usual way to troubleshoot is to check the keypad with a meter if it is OK then replace the control board. Still a bit of a crap shoot but your odds are better.
May just be a dirty connector, see below.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
