My GE Profile dishwasher, PDW7880J10SS recently started leaving standing water in the basin up to the height of the heating element. It will not run until I remove the standing water with a wet/dry vac. Once the water has been removed, the dishwasher appears to run normally, with the exception of leaving standing water at the end of the cycle.
Actions I’ve taken:
- Removed and inspected the filter sump and cover assembly, nothing found.
- Removed the lower spray arm assembly, nothing found.
- Inspected the fine filter assembly, nothing found.
- Removed and inspected the dome float and float, assembly, appears fine.
- Removed the drain hose from the garbage disposal, ran a wash cycle, no water expelled from the hose.
Any trouble shooting ideas? Could it be item #325 the Pump Drain Assembly has gone bad?
Thank you.
