Ge Profile Artica
Compressor is not running. I dont’ see any power coming to compressor. What could be the issue with the refrigerator.
Jasd,
There are several tests you will need to perform, to properly diagnose the problem.
Your technical data sheet, should be located on the backside of the kickplate grille.
You’d be better able to diagnose the problem,
Is evrything else working properly, the fans are running, lights work and the display is proper ?
If you have a multimeter, you may want to perform the following test at the mother board, so we’ll have a better sense of direction to take.
[LEFT][SIZE=1][FONT=Arial][SIZE=1][FONT=Arial]Check for 120VAC at connector J7-9[/FONT][/SIZE]
[SIZE=1][FONT=Arial]orange wire to TAB1 / J11 Black wire.[/FONT][/SIZE][/LEFT]
[SIZE=1][FONT=Arial]Do you have 120VAC[/FONT][/SIZE]
[/FONT][/SIZE][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]No[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]Replace board[/SIZE][/FONT][/SIZE][/FONT]
[FONT=Arial][SIZE=1]I’ve also attached a copy of a service manual for similar models, it may be helpful, for getting an idea.[/SIZE][/FONT]
[ATTACH]2705[/ATTACH]
Good Luck,
Arctica Profile GE Side-by-Side Refrigerator.pdf (1.7 MB)
