I have a built in GE potscrubber. The unit will not fill. I have checked the water going in, fine, I checked the water valve, OK, checked the float switch, OK, it doesn’t seem to be getting any power to the float switch. That is as far as I can get on my limited knowledge of this unit, what should I check next?
Check your timer if you have one. I pull the cover off, spray the contacts with non-residue cleaner, and turn the timer knob around a few times, this usually works.
