The complete lower spray arm and telescoping tower with metal pin that connects to the bottom of the washer keeps on coming out of the hub. Is there a way to disconnect the power tower assembly so that I can seat the pin properly in the Hub?
John Flaherty
John,
What is the complete model number of the dishwasher?
Hi Gene,
The diswasher model number is GSD 1200 T-02. It seems like the metal rod came out of a broken lower support assembly. I don’t know how to take the tower and the gear hub out of the spray arm without destroying them. Thanks for your help. John
Holding the spray arm with one hand, unscrew the tower CCW holding it at the very bottom part. Remove the tower and the spray arm and unscrew the central screw. Pull up the gear hub and pinion assembly and remove it.
