GE Oven
i got a new control panel # WB27K10140 its a little difrent from the old one , my quastion is wer to put the 4 wiers , i have a red blue yellow white, on the board its says 1) bake 2) broil 3)Line 4)AC N RLY101
Thank you
Where they were connected on the old control board? Do you have the wiring diagram?
Here are the breakdown diagrams and Replacement parts for GE JGBP30BEW1WH | AppliancePartsPros.com
Gene, are you familiar with the oven t’stat knob problem which exists on some GE 30" ranges? They changed the timer board to a new design, with a different shaft diameter, thereby making the old knobs useless.
Oven: JGBP30BEW1WH.
Kind thanks.
No, unfortunately I’m not. I never dealt with this board.
[QUOTE=mendel;89130]i got a new control panel # WB27K10140 its a little difrent from the old one , my quastion is wer to put the 4 wiers , i have a red blue yellow white, on the board its says 1) bake 2) broil 3)Line 4)AC N RLY101
Thank you[/QUOTE]
I’m in the same boat have you found out an answer?
Tony
Thank you[/QUOTE]
After trial and error, Red= Line in, White=AC neutral, Yellow= Broil and Blue = Bake
Controller The part # is WB11K65 (the parts store also said it had been rolled into a new number which is WB27K10140)
Hope this helps someone else
