GE oven won't heat past 170 or so
Oven won’t heat past about 170 or so. Broiler works fine. Replaced oven baking element…same problem. I can hear the thermostat clicking but it never achieves the higher temperatures.
Help!!!:confused:
Hi.
Please check the oven sensor resistance. At room temperature you should have about 1100ohm and if it checks OK - replace the control board.
The sensor AP2023913
The control board AP2632445
Here are the breakdown diagrams and Control Panel & Cooktop parts for GE JBP66BY5AD - AppliancePartsPros.com
Post the results.
Simon.
