function scrollwindow(){ try{ scroll(0, 50000); }catch(e){}} [FONT=arial, arial, helvetica, geneva][COLOR=red][/COLOR][COLOR=red][SIZE=5]The oven on my ge electric range is not heating properly. I am having trouble turning it on, the preheating light just flashes. Eventually I am able to turn it on. When I do it will not heat to the appropriate temperature. I turned it on to 350 but it only gets to 200 degrees. I am thinking I need to replace the oven sensor or thermostat. I don’t seem to be able to find a part listing for the thermostat. My range has an electronic control panel, does that mean it doesn’t have a thermostat? My model number is JBP26G S2AD. [/SIZE][/COLOR][/FONT]
With that much of a temperature difference you need to replace the clock control board. Tom
