GE Oven Stopped Working
Would appreciate the help. Stove and broiler works/lights but oven does not work at all. From my reading it appears that it is likely the oven igniter? How do I check and confirm if this is the problem? Thanks in advance for your help!
When you turn the bake function on can you see an orange glow down in the bake area? If you do and the oven gas does not come on to heat the oven, replace the ignitor.
Ardvaark
Thanks for the response. I did remove the oven floor panel, and turned the oven on, but the igniter did not glow at all or heat up after a few minutes.
Check the igniter for voltage or continuity. If there is voltage to the igniter while in bake mode, replace ignitor. If the igniter shows open or no continuity, replace ignitor.
Ardvaark
Thanks for the help!
