Brand: GE
Model Number: JBP35SM3SS
Main Symptom: New control panel- personality setting
What happens & when: We just installed a new control panel WB27X45466. Can someone please tell the correct personality setting for my specific GE Oven? (JBP35SM3SS). Thanks!
For your GE JBP35SM3SS, the correct personality setting for the replacement control WB27X45466 is Personality Code 15.
I verified that your model originally used control WB27T11273, which is replaced by WB27X45466. Sears Parts Direct GE’s programming chart assigns original control WB27T11273 to personality 15. Appliance Parts Pros
To program it, power the range on and use the UP/DOWN buttons until 15 appears. Then press and hold START for about 2 seconds. The control should reboot with that setting. Manuals+
If a personality was already entered, cycle power and, within 5 minutes, hold START + UP for 2 seconds to bring the personality setting back up.
