The above GE Model Stove needs to have the oven door gasket replaced. How difficult would this replacement be and are there any instruction which I could follow to replace the gasket.
The oven door gasket is not too difficult a part to replace yourself.
Remove the oven door as described in the “Use and Care Manual” (page 35) and place it on a flat surface with the front of the door facing down.
Remove all screws holding the inner door panel and remove the inner door panel to access the door gasket.
- The part number for the oven door gasket is AP3853071
