Installed new ERC, got power to it now I’m getting an F2 error code or an F3 when I press broil.
What now ?
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Both of those codes could mean a bad sensor or control you have already replaced the control so replace the sensor. Range Repair Guide[/COLOR][/SIZE][/FONT]
Which sensor ? The F2 code also shows ‘door locked’ msg although the door is unlocked. There is a sensor that looks to tie into the door latch so I pulled the wires from that thinking it would open the switch and therefore cause the error to not reappear, not so same result same error code/msg.
[FONT=Times New Roman][SIZE=3][COLOR=#000000]The Switch for the door lock may be bad. Disconnect the wires from the switch (if that is not what you already tried) and see if it goes back to work. [/COLOR][/SIZE][/FONT]
[SIZE=3][FONT=Times New Roman][COLOR=#000000] [/COLOR][/FONT][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]I was talking about the oven sensor because F2 means that the oven has over heated. The sensor can cause the code to appear. [/COLOR][/SIZE][/FONT]
[FONT=‘Times New Roman’][COLOR=#000000]The sensor should be around 1000 ohms at room temperature. [/COLOR][/FONT]
