[quote=denman;387899]This is the closest I can get to a manual and it is not very good.
31-3280 Clean Design Electro-Mechanical GE Dishwasher Service Manual - ApplianceDigest.com
When you took the assembly out, the sloped flange at the top of the piston should seal to the top of the piston & nut assembly.
The way it works is that during wash, water can go down past the piston by compressing the spring and help feed water to the pump.
During drain the water flow is reversed, now the piston seals this port so that water does not flow back into the tub and it flows out the drain.
It is normal to have about a quarter inch of water sitting at the lowest point in the tub. These units do not totally drain. The pump does not like running totally dry and will burn up the seals if it is run dry so there is always water in the sump.
That is why when you install it you should always add a couple quarts of water before running it for the first time.[/quote]
Okay thanks again…
this does not make sense. I am missing something here or have things backwards
when I first pulled the cover off the inside of the tub to look at the piston/nut from above. The piston was in what I would assume is the “closed position” sealing the tub (flush with bottom of tub), it is now in a recessed open position with the hole opened.
So based on what you are saying, it seems that during the drain cycle the piston is sealing a port that is INSIDE the body valve and check assembly when it is closed and is therefore recessed in the tub and NOT sealing the hole in the bottom of the tub.
Otherwise I would have been draining fine and probably excessively
and not the opposite as experienced
so in the CLOSED DRAIN MODE, I would actually see the piston and nut recessed in the hole/shaft in the bottom of the tub.
In the OPEN wash mode, the piston would be flush with tub, closing up tub hole but opening up a port below?
I just ran up to check it when the washer had completed its cycles and shutoff normally and the piston was fully receased, hole was opened and the normal amount of water was now in the bottom of the tub.
It looks like the problem was either the piston was jammed by debris
at the top of the tub therefore sealing the hole in the bottom of the tub, but leaving the drain port closed.
OR the mechanism that allows the piston and nut assembly to rise and fall within the shaft is defective and causing issues.
I wil have to try and caught this during a drain cycle to see what the piston and nut is doing.
I have not yet removed the Body valve and check assembly from the bottom of the dishwasher. I got as far as removing the two screws and two hoses. I then tried to pull it off and meet alot of resistance.
I am assuming all I need to do is apply more force to pry it off the tub.
It looks like one can add photos of things in the quick reply if that would help.
