Ge Nautilus Does Not Drain
Hi!
Will Not Completely Drain. Checked Lines, Not Kinked, Some Gunk, (@ A Tablespoon) Cleaned Out. If Not That, How Do I Know If The Drain Solenoid Is Bad?
Remove the filter frame (#543 on the break down diagram) and unscrew the piston and nut (#564 on the break down diagram). Check the cone seal on the piston. Replace the piston and nut assembly if the cone is worn out.
  • The part number for the piston & nut assembly is AP2617344
