How do I remove the spray arm? Do I have to go in from under the dishwasher or can I remove it from inside? Also, what tools will I need to remove it?
Thanks,
Tom
Thanks,
Tom
Tom,
What is wrong with the dishwasher?
Why do you need to remove the spray arm?
Here are the breakdown diagrams and Replacement parts for General Electric GSD4100J00BB Dishwasher | AppliancePartsPros.com
[quote=Gene;272543]Tom,
Gene.[/quote]
The plastic cylinder that pops up from inside the sprayarm during washing cycle is broken. How do I get the sprayarm off, and what tools will I need?
Thanks,
Tom
[LEFT]Tom,
This spray arm is threaded into a part under the tub/liner of the dishwasher. A rubber coupler on top of the motor and pump assembly is what this spray arm assembly screws/threads into. To remove this spray arm, simply push a flat screwdriver through the hole in the bottom of the spray arm and twist it off.
Gene.[/LEFT]
