GE MW fuse access
My mw has shut down. I want to test the fuse, but can’t find how to access the part.
Hello jawhite. Remove the outer cover off the microwave. You will see the fan motor on the right looking at the microwave from the front. The fuse is located above the fan motor. The fuse is number 101 in the parts diagram. Hope this helps.
AP3994062
Microwave replacement parts for General Electric JVM2070BH001 Counter top microwave | AppliancePartsPros.com
