GE MONOGRAM Trash Compactor RAM stuck
I would like some help on how to repair our GE Monogram Trash Compactor. Just suddenly when we turn it on the RAM got stuck and wont go up and until now, its been a week and still ram stuck. Afraid that food and trash inside might cause health problem. I tried pulling it out and starting it over again but it didnt work it only opens about 2 inches and you can see the RAM still down sort of stuck. What do I do. How can I disassemble it or have it working again
I am having the exact same problem you had, I didn’t read where anyone responded with a solution. I have removed the unit and have the back panel off. The ram is stuck down, even though the motor and gears appear to turn normally. Any suggestions?
I found the problem (I think). The threaded hard plastic nut that the drive screw powers the scissors up and down with was cracked, and giving itself up toward the end of it’s life. It looks like it went on the downstroke and didn’t have enough friction in the broken part to raise the ram. Thank you for your advice, and I hope this helps other do it yourself types solve what looks to be a common weakness in these machines.
Steve
Warbirdman,
Do you have a part number for the plastic part that mates with the lead screw. I suspected this to be my problem too, and your post confirms my thoughts. I can’t find any parts list for this unit.
Any help in this part number search would be appreciated. Also, where did you get it from and how much $?
Thx,
Dan B.
Bosstool,
I no longer have the part# but you can get it from GE after wading through some of their menus. They will e-mail you the parts breakdown, and you want the jam nut that the jackscrew rides in. It is enclosed in a little sheetmetal container. I shopped the part around, and eventually paid about $28 for it. I think GE wanted approx $50 and so did another local shitbag parts supplier. I hope this helps.
Steve
warbirdman,
I did find a parts list on “********************” website. For convenience sake I just ordered the part from them, after a quick check for other pricing. I paid $44 for this part, called a “trunnion nut” by their description. I took my current trunnion nut out of the sheetmetal case, and it is not cracked but it is “stripped.” The threads are no longer present that would allow a good engagement to the lead screw.
Thanks for your post. I suspected the problem would be this piece, but you post gave me 100 percent confidence that would be it.
You have been very helpful. Great site! I wish GE had a little more information, like a parts list for their product.
Dan
the website is with a place called “********************.” Just put the www and the .com on each end of that name and you get there.
I give up. I am not able to give the name of the place that had the parts list, apparently. It’s out there however.
I didn’t understand your last reply. If you call GE Monogram (Google) they will send you via fax or e-mail the exploded drawing for that part of the compactor. Get the part # for the jam nut, and shop around. It should cost about $5.95, but as I said a GOOD price is in the mid to high twenties. I hope this helps.
Steve
I looked at the ram last night and saw the exact same problem–a cracked plastic gear. Should have read this first. I’m not that handy so it will cost about $300 to get the transmission replaced. I guess the repair man has a family to buy christmas presents for too…
Dear bongobiltmore,
Sorry to hear about that. I bought the part for about $30 to $50 as I recall, and it went in pretty easily, but I got some grease on my hands. The replacement part is now made of aluminum. I came out ok on that one, but I just tried reapairing a dishwasher part that didn’t come out so well. Don’t feel bad, I ended up buying a new dishwasher and probably would have been better off to have a repair guy come out for that one.
You win some, and you lose some. Thx, for the reply.
Dan
Yes, the drive chain has jumped off. Remove back cover after unplugging cord. Locate the chain laying on top of the ram. Put it back on by putting on small gear first and then rotating the large gear. The problem appears to be caused by the very quick reversal of direction of the motor. Some sort of time delay may be helpful.
It appears that the chain jumps off really easy, regardless of amount of trash being compacted. To repair you need to get this from Harbor Freight: 8mm Swingarm Spools Item #66925 for about $5
Also the following tools:
Drill
Tap & Die Set
Phillips Screwdriver
Allen set (Metric & SAE)
Unplug the machine. Remove back cover you see small gear & large gear. If no chain is between them take a light and look down underneath on top of the ram, the chain should be laying there intact.
Put the chain on the small gear and partially on the large gear and rotate it until chain is reinstalled. Don’t be tempted to let it go at this, it will NOT stay on.
Take one of the 8mm spools and mark through the hole where to drill. The spool should be positioned about half way between the small and large gears and on the outside of the chain with the chain resting in the dip of the spool. Drill and tap to fit the allen screw that came with the spool.
Mount the spool. Now the chain should have slight pressure against it from the spool. Do the same thing on the other side.
The spools should be mounted tightly against the metal frame, not loose to spin. The metal initially feels too thin to tap a thread into but it is marginally ok and I think it will hold without further attention.
After doing this my compactor worked much much better and the chain did not jump off (resulting in what you think is a stuck ram).
Now it’s time to figure a rebuild for the drawer front where the bag will not fold over. What a piece of crap.
