My GE Monogram Icemaker Model ZDIS150WSS is not making ice. The cooling plate is warm and has water running over it. I did a diagnostics check and all came back OK, however the Compressor and Condenser Fan Check (Order 7) stays on solid as the Evap thermistor never reaches 4.5 Deg F. I checked the OHMS across the pins on the compressor. With the unit cold, the resistance across the bottom two pins is 11.6 OHMS, across the bottom left and top pin is 8.8 OHMS and across the bottom right and top pin is 3.4 OHMS. With the unit running for several minutes through the diagnostic cycle the readings were 14, 6 and 4.5 respectively. When turning the unit on, the voltage to the compressor reads 10 VAC and the condenser fan does not run. I believe it is either the main control board or the dual voltage transformer. Can anyone help with the diagnosis?
Thanks.
