GE Monogram Fridge Light Issue
I have a GE Monogram side by side fridge. The lights in the the freezer do not work, but they work on the refrigerator side. I know it’s not the switch or the bulb. Any advice?
What is the complete model number of the refrigerator?
[quote=Gene;801440]What is the complete model number of the refrigerator?
Gene.[/quote]
It’s model# zlss360drgss
There is the light transformers tray under the refrigerator (#549 at the diagram). There are two fuses in the tray. Try to reset them and check for continuity. replace if it’s open.
Here are the breakdown diagrams and Parts for GE ZISS360DRGSS Refrigerator - AppliancePartsPros.com
[quote=Gene;801624]There is the light transformers tray under the refrigerator (#549 at the diagram). There are two fuses in the tray. Try to reset them and check for continuity. replace if it’s open.
Gene.[/quote]
That was my issue. I had originally looked there and didn’t realize there were fuses there. Thank you so much as you saved me a service call.
You are welcome. I’m glad to hear it was such easy fix.
Model #ZISP480DHASS light panel in refrigerator not working need help please Thanks
I have a side by side GE Model no PFS22SISBSS.
The display for the temperature both the refer and freezer does not display.
Is there a light behind the display. Tried to adjust the temp by pushing the cold or warmer button but no temp display?
Roland
I have a very monogram fridge freezer. It has 2 lights in the fridge side . One light is out. New bulbs don’t work if I move the live bulb from one side to the other , both sockets turn on. Any ideas
