My built-in Ge Monogram al of a sudden stopped working. The timer counts down and all the lights etc. work but the microwave doesn’t come on or cook. Any ideas?
Hello. Check the door switches. If they are bad, they can cause the microwave to do this. If you need more help, please provide your model number. Thanks. Model Number Locator
re lights on..timer counts down but microwave doesn’t work..
t checked the hinges and do not see anything wrong. The model is ZMC1090WV001
Really appreciate your help!
Hello. You will need to test the door switches, not check the hinges. Here is what the part looks like. Also, make sure the switch holder is working properly on the unit. Hope this helps.
Re:confused: really appreciate your help…can you tell me where the door switch is located?
Hello. Click on this link. The switches are number 81 and 82 in the diagram. Hope this helps.
Microwave replacement parts for General Electric ZMC1090WV002 Counter top microwave | AppliancePartsPros.com
