GE Model TPH21PRSMBB trips breaker
Found fridge not working and breaker tripped.
Brand: GE
Model Number: TPH21PRSMBB
Main Symptom: Trips breaker
What happens & when: Trips breaker when plugged into outlet
Parts or tests already tried: Verified compressor prong resistance is still good.
Check the defrost heater to make sure that it is not damaged. If it is good look for wiring that may be damaged and then also check to make sure that the compressor start relay is not faulty.
where do I go to check the defrost heater?
Remove the rear wall in the freezer compartment and it will be at the bottom of the evaporator coil.
