GE model CES700P2M1S1 cafe electric
Brand: GE Cafe
Model Number:CES700P2M1S1
Main Symptom:right front burner won’t heat
What happens & when: all burners work except right front burner element
Parts or tests already tried: WB24X31698 already replaced all switches to all knobs with part
Photos / video l
Do you know at this point would I need a new 3 element replacement part for front right burner
You will want to check to make sure that there is 240 vac getting to the element. If there is then the element is faulty and would need to be replaced. If there is not then this will be a control board issue.
Are you able to provide the 2 part numbers for the triple element and the control board. Also what is 240 vac and how to I test for that?
240 Vac is the voltage that needs to get to the element. You would need to test with a multimeter and if you are uncomfortable with doing that then you would need to have someone who knows how to do it or a servicer. I am providing a link for the part and I am going to send you a video on how to use a multimeter and how to test an element. It will be for a whirlpool but testing will be the same.
https://www.appliancepartspros.com/ge-element-haliant-12-wb30t10155-ap5791281.html
