Obove the range GE microwave. No lights, no displays, power is good to the outlet. Likely a blown fuse. Where is the fuse located? Online diagrams show the fuse is likely a ceramic fuse, but not where it is located.
Hi.
Remove the top grill and you should be able to see the fuse on the right. If not, then open the control panel - it should be there.
The fuse AP3994062
Here are the breakdown diagram and Microwave parts for GE JVM1870CF05 - AppliancePartsPros.com
Simon.
Your tip was perfect. The fuses are right there just as directed. Unfortunately, the fuses are good, per my ohmmeter, so I had to carry the beast to a repair shop. Brand new 2 years ago, not abused, but dead as a rock.
Thank you much.
You are welcome.
Simon.
Repair shop called today. The problem was a $30 thermal fuse. $60 shop fee, $30 for the device, and $16 additional labor. At lease I saved a hundred dollar service call by taking it in myself (with help!)
Chalk it up. Thanks again.
Signed,
Usetafixmyownstuff.
You are welcome.
Simon.
