The “Time Cook” button on my microwave doesn’t work anymore, all of the other buttons work and we’re still able to use the microwave by using the “30 second” button.
I was thinking of fixing the problem by replacing the Control Panel Assembly, part# WB07X10626.
I found the part (#120) on the GE parts diagram: https://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00048500/00048520.p01.pdf
Could anyone give me their opinion on whether this would fix my issue?
Is it as simple as I think it is?
- Remove the griddle,
- unscrew the panel screw, slide it up and out,
- unplug it
- swap it out with the new control panel
I don’t want to do anything stupid.
