Brand:
Model Number:
Main Symptom: 3-element surface burner remains on high no mater where the knob is set. Des turn off.
Error Code (if any): no error codes
Parts or tests already tried: I purchased a replacement infinite switch (GE PN WB24X47192) for that element. After I installed it none of the 3 elements would turn on at all. The front panel light indicating the switch was on did light. I double checked the wiring to be sure connections were correct. When I put the old switch back on, the element did work again. I think in got a bad switch. Is there anything else I should check
