GE JHP63V0K1 Upper Oven, Lower Heating Element
Brand: GE
Model Number: JHP63V0K1
Main Symptom: Upper Oven, Lower heating element - the two standoffs (supports) don’t line up to rest in the depressions (dimples) in the bottom plate.
What happens & when: The part number WB44X195 is correct, but the supports are welded to the heating element and I can’t slide them to align with the bottom plate depressions (dimples).
Parts or tests already tried:The part number WB44X195 is correct but supports don’t aling with depressions in the bottom plate. How can I slide the supports to align when they are welded to the heating element?
Thank you
This is the correct replacement part for your model, and the standoffs are to keep the element from resting on the oven bottom and should be fine where they are located.
