Brand:GE
**Model Number:**JGBP80WEH1WW
Main Symptom: Oven not working.
What happens & when: Oven igniter doesn’t work. Range and broiler work
Parts or tests already tried: igniter replaced, still not working
Most likely the glow bar. WB13X40208 Oven Igniter (Glow Bar) | Genuine Ge OEM In Stock . Here is a video, but instead of using oil like in the video you can use plain water on the screws or liquid soap as it would smell. https://www.youtube.com/watch?v=Ka3aTKdy7gs
Does the igniter glow at all? If it doesn’t, you can do a quick check with a multimeter. With the range set to bake, go around back and test the safety valve where the bake igniter wire connects. You should see 120VAC there. Is voltage reaching the safety valve from the bake igniter?
