Brand:GE
Model Number:GDE20GGHBRWW
Main Symptom: ICE MAKER NOT WORKING
Parts or tests already tried: new icemaker part #WR30X10093
Ice maker is not getting water. Ran self diagnostic on original ice maker and arms turned but never activated water supply solenoid. Checked voltage at solenoid and has one leg of 110 volts on orange wire. Did do a resistance test on white or yellow wire at solenoid to ice maker connector and found one that was 0 ohms Never had any voltage across solenoid, solenoid has 200 ohms resistance, installed replacement part and still no voltage(ac or dc) across solenoid, thermometer in ice maker drawer says 5 degrees F. Tried moving paddle on replacement part 4 full sweeps as I saw online that would put it in test mode and nothing happened.
