GE/Hotpoint
HDA2100HWW
Issue: Water left standing in bottom after cycle
Parts or tests already tried: So far I have replaced the drain solenoid, cleaned the filters, confirmed that drain line not plugged, confirmed drain solenoid works, confirmed that it does actually drain. Confirmed that I didn’t lose the filter ball.
Narrative: I removed the bottom cover plate and watched it run a complete cycle. It operates mostly normally. The drain solenoid works, and water drains out when it activates and the pump runs. At the very end of the rinse cycle, the solenoid activates but the pump doesn’t run, and water remains in the bottom of the washer. Is it the timer not activating the pump correctly at the end of the cycle? Edited to add, this little adventure started when the original drain solenoid failed (melted down!). Some part reviews suggest a bad timer can cause that - true?
