GE gtw335asn1ww spin test
Brand:GE
Model Number:gtw335asn1ww
Main Symptom:Won’t spin on final spin
What happens & when:after 1 day unplugged it will run a complete cycle then lock out.
Error Code (if any):5
Parts or tests already tried:test 14 sprays water 2 times, locks lid but doesn’t spin, times out
When you run it through a diagnostic, does the shift actuator pass the test? The actuator shifts the gearcase to either spin or agitate. If that checks ok, replace the main control.
