GE GTD65EBSJ2WS New control board on wrong personality
Brand: GE
Model Number: GTD65EBSJ2WS
Main Symptom:Personality on wrong setting
What happens & when: Dial has 12 positions but the board only recognizes 10 in the incorrect positions. The test mode is also off by 1 digit from the manual. There was no instruction manual with the board so with the little info I found, I selected 1 because my unit is electric. Apparently that was incorrect, I need help getting back to the personality menu to fix this. It would also be nice to know what personality setting it should be.
From what I am able to see, this model would use personality 3 for its ID. Here is how to enter into the personality mode as well as what program personality ID is listed.
Yes it looks like 3.Here is the tech sheet and programming instructions!
31-16886-3 GE GTD65EBSJ2WS Dryer Mini Manual.pdf (703.1 KB)
WE22X35978.pdf (203.7 KB)
