Ge- gss221btgcc
Brand: GE
Model Number: GSS221BTGCC
Main Symptom: frost on top shelves of freezer
What happens & when: frost on food and noisy when motor is running
I’ve already replaced the freezer door gasket part # WR24X10302 about a year ago. It stopped for a while but its doing the same thing again. I’ve cleaned and vacuumed underneath but I can’t move the unit to check the back or unplug it.
It sounds like you have an air leak causing the frost and ice buildup up and the noise could be ice in the fan.
https://www.appliancepartspros.com/repair-help/
