Brand: GE
Model Number: GFW850SPN2RS
Main Symptom: Washer won’t drain
What happens & when: Front load washer will run as it’s supposed to but will stay at 13 minutes during the final rinse/spin cycle and not drain, leaving everything in the washer soaking wet.
Error Code (if any): 29, 18, 27, 34, 26, 48, 46
Parts or tests already tried: I have replaced the drain pump, the old one had a crack in the motor housing. I ran a 14 test and the drum spun like normal and accelerated to mimic the spin cycle. I ran a test mode 7 and filled the tank and that worked fine. Then I tried test mode 12 to run the drain and nothing happened. I blew air into the drain hose to see if it was clogged and I was able to see bubbles come into the drum area. I did a software update and it is up to date. The annoying part is that when there is water in the drum and I try to run rinse/spin cycle, everything in the machine stops when it should spin and drain. But when I manually drain the water out and run the spin and drain cycle, the drum turns like it’s trying to spin and drain the non-existent water.
