Brand: GE
Model Number: GFW450SSM1WW / aka GFW450
Main Symptom: Power shuts down and won’t turn back on
What happens & when: After running a load, the power cut off and it won’t power back on. After a couple days it powered on and did a cycle, then it died again on the next cycle, power cut off with one minute left on the cycle. Removed all panels and checked for damage and water, none found. Randomly turned on briefly but as soon as I resumed the cycle it drew some water in and shut off again.
There was a power outage recently, I am thinking it may be related.
Error Code (if any): None displayed
Parts or tests already tried: Replaced 2 broken dampers on left front and rear due to overloading
