Ge gas range
Gas range approx. 15 years old. The display fades out so it can’t be read. It has happened for many years. Previously you could tap on the area around the display & it would light up, but then faded again. Recently, tapping doesn’t work. I think we need to replace something; what part/parts do we need?
You need to replace the clock control board. I would be able to give you a part #, but you are missing a letter and a # at the end. Tom
[QUOTE=kayakcrzy;66500]You need to replace the clock control board. I would be able to give you a part #, but you are missing a letter and a # at the end. Tom [/QUOTE]
The model # from the stove is JGBP26GEN1WG
Hope this helps and thank you.
I have checked 5 different parts sites for your model #, and none are coming up. The best thing you can do is to call GE, and see if they can help you get a part#. Tom ApplianceEducator.com
